Sid
  • Topics: 2
Hi
It’s still only firing on the rear cylinder , I how have 3 cdi now and all are still giving the results,  I brought my new cdi from grandad.com .
I’ve tested the pick up on the  flywheel and that’s seems ok,  I’ve also taken the stator out of the bike and gave it a good clean and then  done a bench test on it and your right it is a little over  what it should be.
If you could see the wiring it looks like someone had taken  a chainsaw to it and reconnected it all  with push fits And electrical type lol , So I think I will need  to sort this wiring out first to make sure All the connections and wiring are good, I don’t want start spending money on stuff that I might not need .
