Mar 4, 2024 at 8:39 AM
#12491
Put in gear with the engine off pull the clutch in & can you move it? If you can then it’s going to be something to do with the side stand switch the connection that it plugs into can get corroded so contact cleaner, you can try bridging the connector with a paper clip/wire to eliminate that.
