Ucvmn
Okay, Try this… Take out the spark plugs and show me ? Are you also using standard CR8E ? (I hope so) Next , remove dashboard ==> Remove fairings ==> Remove tank ==> Follow the “BLACK & YELLOW” wire from dash board to front coil = check for any ohms It should go from 0 omhs to infinity 9999999999 ohms = If it stays zero, harness is broken somewhere and dash board is not able to read signal from front coil. Also check black yellow wire from front coil to rear CDI unit = check for circuit is complete with your meter ? When your bike is running =-==> Check under bike for “sparks” escaping the ht wires on the coil (coil damage) Soon = we may need to replace your stator and regulator again , but i cannot remember if i send you Stator & Regulator for you 125cc a long time ago and you need new parts for a 250cc now ?
Yes, I’m using CR8E spark plugs.
A few weeks ago, I bought a regulator from you along with other things, but not a stator.
