Hi I’ve tested the white and blue wire and the front coil black and yellow wire and these ok no wires broken . I have tested the two pin wire coming out of the stator and it shows 2 homs, I’ve also tested the stator the voltage regulator or (R&R) and the battery and both coil packs and all seem good And I do have a power jump box just in case I need a bit more kick , All I have to do now is test the harness, If that is ok then i’m stumped 🤔
What “Ohms” was the stator 2-pin plug ?
Don’t jump start on a live running car or truck  = that’s how it fries everything.
You can take the battery out of the car and test with your bike inthis case or make sure the car/truck is fully off and runs 12V!  (some vehicles are 24v!)
Good luck!
