Check your float height , after every ride on my carb bike = the big filter is usually full. Or your float needles are jamming causing some internal engine slow leak of fuel in to cylinders = Your manifolds will be “wet” inside as a hint.
Also open “OIL FILLER CAP” ( on the clutch cover) and sniff inside hard. ==> If you smell fuel => change oil before riding again.
Can you also clean your spark plugs , go for a short ride => wait to cool down => Take pictures of spark plugs so we can see the mixture ?
Simon also has the EFi 250 motor, he knows if the fuel system is too rich or too lean,. Pictures of spark plugs will help
OR
It could be electrical! (Coils? Stator unit?) (Since stator is also part of ignition system = high revs , more pulses to cdi , cdi talks to coils to spark the plugs. , dashboard tells you how much RPM engine is doing
