Feb 25, 2024 at 6:25 PM
#12388
Could be these in order….
- Solenoid Relay (common)
- Battery too old (Cells have aged , so won’t hold juice , hence the rapid drop from 12v to 9v when pressing start) = The dash almost dims out completely too.
- Battery may be new (if bought in 2024) but charging system is wanning , so next morning battery is not fully charged up to crank faster
– 14v idling and 14v @5k revs ===> If less , replace regulator. Don’t buy china ones , they always (yes, always) burn the terminals or go on fire.
Stator = Should be 80v @5k revs at every 3 yellow wire (eg. 70v, 70v, 70v) => Service manuals in this forum show how to test it. - Starter Motor unit.
- ==> Hope not => Open your stator cover after you drain oil first = Look behind to see if your Flywheel Sprocket is missing any teeth.
– or – starter “clutch bearing” is phasing out. => could be time for a new one.
