Hi mate, I’m using the twin dial clocks but the 250 clocks are different to the aquilia mate the fuel gauges are a totally different shape I’d have to send you pics when I’m home at the weekend to explain it properly, I have some 125 clocks and the fuel gauge is different. I’ll send you some pics at the weekend to explain properly. Cheers
You might have the early rare pre-650 version  without the “temp gauge”    on 650 ones but 250 ones have no temp gauges so put fuel gauge in the middle spot , i see what Korea did there and change the wiring loom too!
Hmm i suppose , it might be possible to resolder something up when you take from a 125 in to a 250 dash casing! 😬☠
