Michael
Thank you for the reply, Marcel.
Unfortunately, I didn’t fully state that i’m (somewhat) familiar with these bikes, and of course bikes in general.  What i was actually looking for was the repair manual part number, so i could research the stock jet size.  As stated, the electronic manual i have lists a 125 front, and 122.5 rear (as the rear is smaller due to the heat from the front cylinders, at least that’s the theory i found), but the paper manual lists a 130 for both.  That’s a size difference of 5 in the front, and a 7.5 in the rear.  As per your post, that’s above the OK variation
And, since i have a modified airbox, i’m thinking it will be larger than stock.  BUT, the PAPER manual starts out bigger.  Now, as you know, it’s better to go rich than lean, but I was hoping to find the starting point, at the very least.
Again, thanks for the reply.  I appreciate it.
