Hello again! Sorry for the delay. I’ve had some other bigger focuses come out of nowhere in the last few months so I haven’t had any time. On the plus side I passed my full A licence test 2 weeks ago so the L plates are off.
I did a compression test earlier today and i can confirm both the front and rear cylinders read the same value of 140ish psi. I had no luck with the hard tube but the screw in hose worked well enough.
Now here’s where things get interesting. When I pulled the plugs and before I ran the test i spun the engine over for a split second and it spew out a considerable amount of raw petrol out of the cylinders. I’m amazed it didn’t hydrolock! This now means that there’s something else going on. It would also explain why the front cylinder wasn’t firing, it was probably getting fouled something chronic.
So my next bet is to pull the carbs off again and re-do everything. float heights etc. Plus change plugs and do oil again.
Knowing I double checked the floats and seats before i tried getting the bike running i’m surprised but hey at least the bike has good (consistent) compression.
Any further advice would be useful. Thanks again!
