Hardy
  • Topics: 1
Hi Simon
Thanks for responding to my question.
Tried cleaning all the connections but still nothing.
Checked the harness connector red wire has battery voltage, orange wire has continuity to negative on battery so I’m thinking those are good
Checked ignition switch connector red and orange ohm out when key is in on position and the other two wires when key is in off position
Put the battery on a charger overnight and going to check some of the grounding points on the bike  next.
Read a post somewhere (can’t remember where) but someone had the same issues and he said he was able to push start the bike and while running everything was normal again.
Doesn’t really make sense as it seems that somewhere in the ignition circuit there is something that is not allowing it to start normally.
However I will try that.
Thanks
Hardy
