I can hear the exhaust more than the bike 😉
Sounds like few things you could check below
  • Air box isn’t sitting on the carb properly (CV vacuum loss to maintain idle)
  • Mixtures messed with and Pilots are clogged again. (it sounds like its hunting for fuel to maintain a stable idle)
  • Intake Manifolds (more rare than the bike itself!) may have a split from the shop that may have stress fitted the parts instead of being gentle
  • Please make sure they did not use stupid things like “silicone” to seal the inlets to the engine heads instead of using proper orings like we have on the shop.
  • While the bike is running ==> Look at the ignition coils for sparks flying out of it.  If yes = switch off and replace HT wire immediately replace the CAP , COIL,  SPARK PLUG all three at once , if it is still using standard parts from Korea.
  • If it has “IX Blue” plugs = Bin them and use CR8E or NGK Laser only.
  • If it has NGK caps , check the HT wires so no sparks is coming out of the cap or coil or loose wiring.  (screw HT wire slowly clockwise until it stops for a tight fit so it doesn’t vibrate out)
If it is “loud metalic” ticks , then
