Sep 8, 2023 at 11:50 AM
#11160
Sounds like weak battery if it can’t handle lights being ON and trying to crank it at the same time.
I would recommend a fresh battery from halfords or SportsBikeShop website (trusted) , to get YUASA YTX 14BS , little batteries degrade faster and will soon mean new starter motor and relay , engine is happy when battery has around 200CCA capacity to crank considering its a thirsty 2 piston vtwin.
Then confirm yourself or replace regulator or stator unit , if the following fails (even korea says change it too in their manuals)
– Idle Voltage = 14V DC (max 15v/14.8) —> Lowest accepted 13.6V
– 5,000 rpm voltage = 14v-15v (If it is 13.xx above 3,000 rpm, replace regulator, it will burn)
