Aug 26, 2023 at 7:03 PM
#11093
The fact it’s both sides messing around says its probably the connector blocks behind the headlight unplug spray with contact cleaner, the starter switch could be the side stand switch playing up.
Thanks, I will do that and update with the results.
P.S.: I already bypassed the side stand switch because it was causing my bike to shut down while riding, haha.
Also, today I noticed that when I press the start button and the bike does not start, I can see the neutral bulb dim, and I can’t hear the starter relay either. It could be the starter relay, but that does not explain the horn button issue.
