Simon
  • Topics: 1
I’ve been considering this issue (I own the 250 fi) it’s going to be a process of elimination, first thing the easiest to do is connections unplug & clean all the connections with contact cleaner, there’s several under the tank along side the air box, the fact it’s not throwing any red light says that the ecu thinks everything is OK. Now the sensors regardless of what they do work pretty much on resistance so this controls the the injection time, next is the compression test if that’s OK then a valve check would be next.
