greg
  • Topics: 1
I think they fixed it. it already has normal rpm at idle. reacts quickly. to add gas
cause it didn’t work on the rear cylinder . there was a Air Mixture Pilot Screw . its end was broken. blocked the fuel or air canal . i was able to get out. needles from the other side .I installed two new screws and it works fine now .
which does not change the fact that . that the crankcase ventilation was clogged. After removing the screw, nothing is hissing anymore.fuel tank only. sucks in. I don’t know if it’s normal or not .pasting links to videos
