YUASA YTX14BS – It is the factory size and the battery try is designed to accomadate it.
before fitting a new battery , make sure regulator is 14v at idle and 14.6v max at 5,000 rpm and test your stator output too.  A good charge system will see your battery even pushing a good 3yr life span. Instead of changing it every 6 months on a bad charge system.  Just have a look, incase previous owners did something foolish.
Don’t buy lithiums  (no matter what they tell ya) , if in doubt , trust korea’s own manuals when they say use the typical maintenance-free AGM battery
If you can’t get YUASA,  try VARTA or UNIBATT, as those are good brands.   Not to sure on everyone else as some batteries use really cheap parts inside / cells even if the battery has a flashy logo.
