Jul 10, 2023 at 8:01 PM
#10712
Now did it spark after pulling in the clutch ?
If it doesn’t spark?
– Check coils or replace
– check HT caps and spark plugs
Also the sparks are cut off by
- side-stand switch even if its bypassed , maybe the wires rotted ?
- clutch switch (but this should not be a problem if it cranks with lever pulled in now as you said)
Last war for sparking will be the
- CDI unit
- stator (pulse sensor needs to work before the bike even thinks of sparking) , the cdi wants to know the stator pulse sensor works 1st
