It is okay, sorry i was not clear.
On your handlebar for the clutch, there is a switch wire , follow it.  And check it is connected.
Temporary use paper clip to join the 2 bullet connectors  (do it safe)
Then check for sparks on the bike.
Make sure to squeeze clutch lever before starting
We want to see if a “temporary” bypass of the clutch switch wire works.
Also check side stand ,  follow its wires, you will see a “BLACK 2PIN” plug under the airbox that has 1x brown wire and 1x black wire.
Bypass them forever, the side stand switch is very annoying on carb bikes, it is not great!
Just remember to check side stand before you ride away! 🙂
Then we shall focus on the switch gear is working correctly or not… it will be the last item to tell solenoid(big golf ball relay near battery) to crank the bike.
