This sounds crazy but are you very certain the
  • Clutch Lever Switch is working ? = if not, cdi cuts sparks off.
  • Side Stand Switch  (bypass it)
A carb bike will still “crank” without sparks,  if the Solenoid circuit is complete all the way to the cdi and switch gear.
It even cranks without a CDI and reg rec.
So i’d look at the right switch gear is actually sending the signal to trigger the solenoid to spin the starter motor >?
