That is indeed very strange.
To confirm this,  get a bucket that has  0.5 , 1.0 , 1.5 , 2.0L markers inside.
Drain the oil and see how much is drained off.
If it is 1.5L exactly , it should be OK because there is no other place engine can get more oil without Rider adding more inside 😉
However, if it is 1.8L , then it is OK as that is max level the whole engine consumes  (because of left over oil from crank , stator , flywheel , clutch , oil cooler, valve head….sometimes not all of the oil is drained away)  thats why korea says put 1.5L next time you service bike or 1.6L max if you also change oil filter.
Also change oil filter now to be on safe side.
