Dennis
Thanks a lot for such an informative reply. Obviously going electric is a bad idea. The main reason which caused me to come up with this idea is because I have started to experience jerking while riding in a higher rev range. So far I have replaced the plugs, fuel filter and cleaned the air filter. I have also taken the fuel pump apart to see whether there was any particular dirt in it but everything seems fine. It also seems to pump out the fuel quite well proportional to the engine revs. The bike is used on a fairly regular bases so I don’t think that any fuel residues could have caused any blockages in the carbs and to be honest it seems that removing the carbs on this bike is quite challenging and I would like to consider this as a last resort.                              Has anybody experienced something similar to this? Any ideas what could be the cause?
