Jun 26, 2023 at 7:35 PM
#10599
Usually the fork is 50% preloaded or 60% , that is if its all the way zero and all the way full (excercise trail and error here) , or for example if it takes 10 full turns, assume 6 turns is the sweet spot , complimented with 15w fork oil but 10w is OK. Korea tends to put the soft 5w which is too thin over here in UK with our winding roads lol.
If you take apart the fork assembly and inspect anything that’s causing the screw to go in a continous loop or you may have to rebuild/replace the faulty fork part.
