Apr 20, 2023 at 6:54 AM
#10208
hiya marcel iām sorry to bother again, the bikes been in at the garage for over 2 weeks and have just got it back today, they fixed a few things- fixed an over pressurising fuel tank changed plugs/ coils valve clearance/ carb balance i rode it when i got it back, seemed fine until i did a top speed run where it cut out at high speed, im so stuck with it and any suggestions will do
Fuel Tap wanning (common)
Fuel Pump wanning or needs a minor clean
Fuel Filter clogged or facing wrong way
Carb Needs *optimizing*
2 weeks just to do clearances and optimize a carb (apparantly).Ā They are taking the piss as i would have had it done much sooner.
Also explain a bit more about this top speed run?
