Visually?
How about these for most bolt on ?
https://www.ebay.co.uk/itm/256002660316
https://www.ebay.co.uk/itm/255976367096
https://www.ebay.co.uk/itm/255972934812
https://www.ebay.co.uk/itm/255947344973
Now you can still use your oem indicators too.
The real issue now…
GTR harness for “headlight” potion will need rewiring
It is advised to buy another “Headlight Harness” for GTR that is damaged , as a way to custom fit “GTR Main Loom” to GTR headlight (retrofitting) to GT headlight
OR Universal for that matter.
Universal = Generally i avoid them , but just be sure whatever seller says should have 45-60mm brackets to hold it to the forks, but you can always measure fork legs. The fork legs have dips that can drop or rise its thickness.
What about your dashboard ? use this mount below
https://www.ebay.co.uk/itm/255997354711
Did this help ?
Before i can advise about bars , switches , next , unless you know what you are doing 🙂
