Viewing 3 reply threads
    • #15340
      Brian
      Appolagies for all the questions, I am learning as I go. If my plugs are burning rich, which way should i adjust the air mixture screw? Should there be less air or more air to correct this issue? Thanks in advance!
    • #15344
      2.5 turns out each pot.  Leave it there forever & ever.  If there is issues , the bike needs attention elsewhere  (meaning leave mixtures alone after this)
      Factory is around 3 turns out each.   I would NOT try to go below 2.5.    Jetting is easier than messing with mixtures.
      If the plug is “oily” with oil drops , consider the valve head seals like this one
      Engine Valve Stem Guide Oil Seal (x4 Seals) – Various Hyosung Models
      But inspect the plugs first ,   then fit a NEW set of CR8E  , as old plugs that are fouled won’t make full power anymore.
      Service manual says plugs are that are fouled  (either too soon or ages go) must be changed right away.
    • #15349
      Brian
      Appreciate the feedback Marcel, I will be seating the valves this week when my head gasket arrives, I ordered it from your shop. Thanks again.
    • #15350
      Brian
      I think there is just carbon on the plugs. Will try this
