Viewing 3 reply threads
    • #14831
      Amit noble
      I’ve been having problems finding neutral on the bike. While driving the bike it shifts through all the gears smoothly but I feels like it skips neutral. I can’t “find it”. I was wandering if there’s a way to make it easier to find
    • #14835
      It is either of these…
      Bad Oil =  Replace the oil ===> Hyosungs love Motul 7100 and Silkolene Pro 4 oils.  Very very good oils.
      Clutch Plates too worn or problem with thrust bearing inside clutch ==> Overhaul clutch
      ARM behind engine for clutch cable needs to be closer to sprocket cover when bike is in neutral  (Clutch Adjustment Tutorial)
      FOOT SHIFTER assembly is dry and needs grease  , ==> Lubricate the joints around the foot-shifter assembly.
      Rear Wheel Chain is too slack or too tight ==> Check chain tension  (yes believe it or not) , it can affect neutrals too.
    • #14839
      Bronski
      Too much or too little oil can make neutral difficult to find.
    • #14849
      Good point!
