Viewing 3 reply threads
    • #8950
      bradley
      Hello guys so I had a previous problem where my cluch would slip the rpm would spike and the bike would slowly catch up to speed.  I had a new cluch fitted (plates and houseing) for about 2 maybe 3 weeks it’s was going well never missed a beat.  but now it’s happening again i have  checked the oil and cluch cabel and its all adjusted well. I checked the gear sector and it goes in to gear everytime not sure what I should do next if there is anything I can do before I contact the mechanics I took my bike to
    • #8951
      Jim
      Sounds like you are doing the correct things. What about sacked clutch springs?
    • #8952
      bradley
      Hello Jim my mechanic got the full cluch assembly direct from hyosung so I suspect thay came with the springs
    • #8953
      By any chance did you or your mechanic follow this guide to the T?
      [Tutorial] Hyosung GV/GT 125 & 250 Clutch Plates Replacement How To
      If the plates and springs were OEM (they would be inside original hyosung bags) , then i can also suspect clutch cable , lever , and the arm behind the engine not fully adjusted perfectly
      So bike rides on new plates hard but wears them down faster (premature wear) as arm behind the rear engine seems to be slightly be pushing the plates , even though bike is in neutral.
      Quality oil really matters too.  If in doubt , just put Motul 7100 and new oil filter and don’t trust what oil that garage uses  (not to trust their lips either)
      Oil change tutorial is here
      If you have an aftermarket clutch perch holder at your handlebars, be ready to replace it as all chinese based universal clutch lever/mounts actually snap cables or stretch them out ,   then alas, your clutch springs get annoyed , so you will end up redoing the whole clutch.
      Changing the clutch thrust bearing is a good shout, to maintain smooth transitions when changing gear, as both inner & outer baskets spin.
      If i missed something else on your bike , please let us know what else it’s doing or even pictures of your bike of anything you not sure of.
      I hope my reply gave you some extra insight 🙏
