I just removed a striped safety torque bolt from my 2009 gt125r exhaust front downpipe as my new blackwidow exhaust came today were can I get a replacement bolt for the damaged one I removed thanks.
I hope not, if anyone owns a 125cc will tell you dealing with Torx bolts is their worst enemy and they tend to replace the entire engine bolt set.
Look at this , you will do a whole lot better here
Header Pipe Copper Exhaust Gasket & Full Stainless Stud Nut Kit :: Hyosung [Various Models]
Remember if its a “Hyosung” the consensus is to try to make every small screw stainless against the harsh weather elements & less fighting when its maintenance time.
If its just 1 bolt you need, do you have a local car shop? Just walk in with the damage torx bit and ask for this exactly below
“Hi, this bolt is for my exhaust but its damaged, can i have a stainless steel replacement ? The bolt must he a “HEX” head please. NO ALLEN KEY.”
Or “This above ^ happened, and i need a “stud that is 40mm long” and an “OPEN STAINLESS NUT” (This will be tricky for them to do!)
but you get the gist sir 🙂
