Viewing 3 reply threads
    • #2408
      Nicpsc
      What would be a good chain an sprocket match for my 08 Hyosung GT250R I’ve got my eye on the jt chain an sprocket set chain is a 520 don’t know about the sprockets though
    • #2413
      Generally over here in UK we use this kit by many 125 n 250 owners.
      Uprated Japanese 520 Chain & Sprocket Kit :: Hyosung GT125R GT250R GT125 GT250
      Also the best front sprocket aftermarket would be the UK made RENTHAL ones.  They are on the shop page.
      I am looking to see if I’ll stock up PBI (US) sprocket, i believe i may have found one but will be sure soon lol.
      As for chains. You will want to use a japanese one over cheap aluminium copies.
    • #2414
      Nicpsc
      Thank you an also what’s the gearing to make it have a little more acceleration I know it depends on the front sprocket but is it the more teeth it has or the less teeth it has that makes it have that little extra boost?
    • #2416
      Hey,
      Depends on the stock that’s ready to go , combinations of 13 / 48  , 15 / 42  are the normally the best ones and the chains max out 100-105 , that’s already the limit of the 250 , sometimes i send 13/46 in some orders  –  All 3 combinations i said , add some acceleration without affecting gearing too much.
      I know sometimes even  a stock 125 has 14 / 52  . Just dropping to 13 without rear, is too much lol. Fast take off sure, but top speed is sacrificed now.
      The GD250 uses a GT250 sprocket carrier , but it’s sprocket is now factory 48T instead of  46 on GT250  , i think that probably helped it take off a bit better lol.
      Hope i made sense!
