Viewing 3 reply threads
    • #20171
      Heather
      Does anyone have a pin out diagram for the CDI box on the 2007 GV250?
      I am using a donor CDI box as the original CDI box that came with the bike was cut off (of course), so i have zero idea what went where and since the original gv250 schematics are sketchy……. basically I need to know what the green wire with blue tracer coming up from stator area is? Neutral safety switch? And if that ties into the CDI box as well as…..the donor CDI box calls for two pulse generator wires. I have the blue wire coming up from the magneto and I assume the green wire that ties in with the red and black wire from my ignition switch (key switch)?
      I’m so close!
    • #20177
      Heather
      Nevermind, everything is at a dead stand still until I can get this disgusting, green putrid mess out of these carbs  Yuck!
    • #20182
      The GV250 & GT125R = Both share the same pin out.    Yes the 125cc is very common in EU ,  the baby version of the 250cc Hyosungs!.
      Hope this helps below and good luck cleaning those carbs out.
      Needing a little help with my current project (+GT125 CDI PIN OUT)
    • #20188
      Heather
      Marcel you’re amazing. I just realized I do not have my pickup coils attached to my CDI. I’ll be back!
