    • #7760
      Gareth rich
      Hi I have hyosung gt125r I got it started up and now I am not geting a spark what can it be please
    • #7763
      • Side Stand Switch  (bypass it) (bridge wires and protect it from rain with tape) be OCD about since hyos really hate it when water gets to the electronics
      • Clutch Lever Switch (see this item here ) – don’t try to bypass it. It is there for good reason for the benefit of the gearbox too.
      • Stator Magneto – > Check resistance of the pulse sensor with a meter  under 200 ohms and tell us what it says
        (Blue & Green Plug from the stator)
        (Bike stays OFF, keys Out of ignition)
      • Stator Magneto -> Do the same with the 3 yellow wire plug  (Pin 1 & Pin 2 = Ohms?  ,   Pin 2 and 3 = ohms ?  Pin 1 + 3 = ohms ?)
        (What is it under 200 ohms? Tell us.   3 tests ^ above ,  3 results . eg.  1.2 , 1.4 , 1.3 ohms = each yellow wire has its own ohm reading. it’s called a 3-Phase stator)Dead stator = No sparks will happen. So this is important to check.
      • Make sure regulator is disconnected  (it will spark without it) but plug it back in when bike runs because it is there to “charge” the battery & provide “running” juice -> when bike starts.
      • HT cap failure  (common) – we use NGK to remmedy this.   or measure resistance of the oem caps by themselves WiTHOUT the coil attached
        (What is it under 20k ohms ?)
      • Ignition coil  (common) , usually one of the first few mods changed on carby bikes.
        Or measure their primary & secondary resistance)
      • CDI unit – I hope not.
      • Wiring Harness – I hope not, only cross this bridge after dealing with the parts above first.
