    • #6788
      Mike Daborn
      I ordered a fuel tap from Hyosung Spares UK for a GR125 and they sent the tap below which is incorrect. Does anyone know what bike this will fit and  if so is anyone interested in buying it? Hyosung Spares agreed to refund for the item if I return it but not postage even though it is their fault. Postage is higher than the item value so I would rather sell it. The fuel tap is brand new.
    • #6791
      GT125R = All years
      GT125P = Circa 2010 onwards
      GT250 Naked Carby = 2005 – 2008
      GT250R – 2005 to 2008
      <hr />
      Sorry if you see this reply twice  (as i replied elsewhere you posted),
      That’s for fuel tanks that with a built in vacuum tap (pictured you posted)
      That’s when the later UK GT bikes had black frames and did away with the “external” tap system.
      I don’t think there is anything wrong with the external tap system, it does last a far while better than the korean vacuum type.   The externail silver frame tap has a hex/square block at the bottom that can be taken off to get rid of any dirt traps, while the filter does the job of filtering particles before it reaches the fuel pump.
      The “spigot” (tall things) inside the tank have a little mesh on top for 1998-2004 era 125GT bikes and the external tap likely has one too,  2 spigots = 2 pipes from the tank down to the external tap system.
      I may find a diagram if i confused you.
      Hope that clears it up!
