- This topic has 5 replies, 3 voices, and was last updated 2 years ago by
Brian.
Oct 29, 2024 at 7:23 PM #15392
BrianParticipantJust rebuilt the front head, new gaskets, lapped valves, used piston, new rings, and still low compression. 100psi. Checked valve clearances, intake reads 0.08 0.05 exhaust 0.10 0.10. Could this cause the compression issues? Thanks in advance
Oct 29, 2024 at 7:24 PM #15393
BrianParticipantForgot to mention, added a little oil in cylinder and only went up 25psi so rings are ok. Just need broke in.
Oct 29, 2024 at 8:19 PM #15394
SimonParticipantThe intakes should be between 0.1mm-0.2mm exhaust 0.2mm-0.3mm when cold. To tigh clearance will open the valves to soon & also as it warms up likely to keep the valve slightly open.
Oct 29, 2024 at 9:21 PM #15395
BrianParticipantThank you
Nov 3, 2024 at 7:24 AM #15426
LaserBeamParticipantJust rebuilt the front head, new gaskets, lapped valves, used piston, new rings, and still low compression. 100psi. Checked valve clearances, intake reads 0.08 0.05 exhaust 0.10 0.10. Could this cause the compression issues? Thanks in advance
Did you put new rings on old pistons, then pop them back in to old cylinders?
What did your cylinder walls look like? Do they have deep, vertical scratches?
Did the old pistons have scratches that match the scratches on the cyclinder walls?
Rings are important & relatively easy to swap. Honing the Cylinder walls is pretty darn important to but it’s messy & expensive if you get a pro to do it properly.
I jrecently did it myself but didn’t do my valves yet, Perhaps you could help me with that?
I’ll be doing a photo tutorial of my D.I.Y. rings, pistons & cylinder honing.
My guess is that you’ve got a lack of compression from slightly worn pistons & cylinder walls. It is possible that your timing is out a bit – that makes it seem like low compression when ridiing. Your exhaust valve gaps should be 0.2 – 0.3 for a 250 i think. What bike is it? Bigger shims in there should sort that out. The Intakle Clearances should be 0,1 i think, so you could add some shims to those to open them up a bit more too. As it is i dont think your bike is getting enough Fuel/Air in or exhaust out. It’s not bad but you may notice better power with more open valves, if it is a 250.
PS. I’d buy 2x new pistons, with rings, pins, retaining clips & both head gaskets. Hyosung have them but aftermarket piston kits will save you a few dollars. I highly recomend the Original Equipment Hyosung GASKETS – they are like rubber, not paper. I used a paper gasket on the head and an orignal metal gasket above it. The paper is ok but for stator cover & clutch cover gaskets, the hyosung ones stop oil leaks way better.
Nov 3, 2024 at 4:36 PM #15430
BrianParticipantYe I honed the cylinder before rebuild and the walls where fine. Timing is spot on, only thing that needs doing is valve clearances, if that doesn’t work new pistons and rings it is
