- This topic has 29 replies, 3 voices, and was last updated 5 months, 2 weeks ago by
Cobra2.
Apr 12, 2026 at 11:48 PM #22280
HawkonairParticipantHallo Zusammen,
Was brauch ich alles von 125 auf 250 umzubauen??
Hab gesehen, dass der 250 eine zusätzliche elektrische Kraftstoffpumpe hat, muss ich die auch umbauen?
Oder reicht es nur Motor und CDI von 250 zu nehmen?
Gruss
Hawkonair
Apr 13, 2026 at 12:02 AM #22284
Apr 13, 2026 at 8:24 AM #22303
♠️ M77KeymasterHi , If you don’t mind , would you be able to let us know what you were saying in English please?
Apr 13, 2026 at 4:01 PM #22313
HawkonairParticipantHi everyone,
What all do I need to convert from a 125cc to a 250cc?
I saw that the 250cc has an additional electric fuel pump. Do I need to swap that in as well?
Or is it enough to just use the engine and CDI unit from the 250cc?
BR,
Hawkonair
Apr 13, 2026 at 8:09 PM #22316
♠️ M77KeymasterIf its an EFi 250cc , you need the full donor bike (EFi Tank, All electronics, Exhaust because it has lambda sensors , EFi airbox, EFi dash)
This is assuming you are using an EFi 250.
Otherwise if it is a carb model, upgrade your 125cc jets to 250cc one and keep using the 125 vacuum pump (that electric pump in picture is worthless = too many problems that’s why Hyosung used vacuum pump on all carb models after this)
Apr 13, 2026 at 8:16 PM #22317
HawkonairParticipantIt is a 250 Naked Model from 2005 with Mikhuni Carbs.
I Read that 250 musst have a elektric full Pump…
I heard the 250 needs an electric fuel pump to keep up with fuel delivery at higher RPMs.
Can I use the vacuum pump, tank, and the rest of the setup exactly like on my 125cc?But doesn’t the 125cc have a narrower intake manifold with one of those nipples in it?
Apr 14, 2026 at 4:46 PM #22321
HawkonairParticipantI need help
Apr 14, 2026 at 5:40 PM #22322
HawkonairParticipantAre the intake hoses of the 125cc and 250cc carburetors on the cylinder head the same?
Apr 14, 2026 at 6:19 PM #22323
HawkonairParticipantIf I convert to vacuum, can I use the intake hoses from the 125? With the carburetor setup from the 250?
Apr 14, 2026 at 8:50 PM #22325
♠️ M77KeymasterIf I convert to vacuum, can I use the intake hoses from the 125? With the carburetor setup from the 250?
Yes you can.
Apr 14, 2026 at 8:58 PM #22326
HawkonairParticipantThx Marcel
Do I only need to swap the main jets, or do I also need to replace the pilot jets and other parts in the carburetor?
Apr 14, 2026 at 8:58 PM #22327
HawkonairParticipantI also disabled the secondary air pump immediately.
Apr 14, 2026 at 9:06 PM #22328
HawkonairParticipantI Found this
Apr 14, 2026 at 9:07 PM #22330
Apr 15, 2026 at 8:51 AM #22333
♠️ M77KeymasterUse 250 jets pilots and mains, because of bigger pistons, or it will be lean and burn a hole in the piston.
Don’t worry about the vacuum pump, all 125 / 250 are using 650cc pump – Hyosung uses a 650cc pump on their 125/250 motors. So if a GV650 can use the vacuum pump, your 250 will never max it out.
Good luck!
Apr 15, 2026 at 10:02 AM #22336
HawkonairParticipantShould I only change the main jet and pilot jet?
Because according to Hyosung’s technical data, I also need to change the main air jet, needle jet, and starter jet.
I wanted to raise the needle and install a sports air filter.
I also have a 95 and a 98 main jet; would that work as an upgrade, or does it have to be a 95 and a 97.5?
Thanks for your help, and I’ll let you know how it goes.
Apr 16, 2026 at 8:11 PM #22340
♠️ M77Keymaster95 + 97.5 Mains.
20 + 20 Pilots
And that’s it. Dont worry about other carb parts.If using a sports filter, make sure its a K&N or BMC etc, as Hyosungs do not like “pod filters”, they will refuse to run correctly with no OEM airbox.
Apr 16, 2026 at 8:35 PM #22341
HawkonairParticipantI’ll use the 250’s carburetor setting, only the front main jet to 95 and the rear main jet to 98.
Can I use a 98 in the rear, or is a 97.5 strictly necessary?
I’m using a BMC air filter and will install a full Turbo Kit exhaust system.
Apr 16, 2026 at 8:36 PM #22343
Apr 17, 2026 at 6:02 PM #22349
♠️ M77Keymaster98 is too much fuel, it will end up washing down your piston walls. 97.5 is max but it will be fine in 92.5 and 95 (factory setup) , so 98+ is overkill.
Apr 20, 2026 at 6:24 PM #22356
HawkonairParticipantThe first carburetor is from the 125cc, while the second image shows the one from the 250cc.
Since I’m converting to a vacuum system, I noticed the 125cc carburetor has differences that the 250cc doesn’t. Do I need to use the 125cc carburetor body and install all the internals and controls from the 250cc into it?
Since I see this on the 125cc carburetor, I assume it’s also part of the vacuum system, right?”
Apr 20, 2026 at 6:25 PM #22359
Apr 20, 2026 at 6:27 PM #22362
Apr 20, 2026 at 6:32 PM #22363
HawkonairParticipantIf I take the caps from the 125cc carburetor and install them on the 250cc one, that should be enough, right? That’s the only difference.
Apr 20, 2026 at 8:58 PM #22364
♠️ M77KeymasterYour just have older style carb, use the 125cc as it is updated. It has jet pump on the side. It is not critical , but helps a little bit on throttle that is all.
Coils = Same for all GT/GV carby models for 125 and 250cc. You will be fine. Otherwise, take 250 electrics and put it in 125 if you’re worried and keep the old 125parts for spare.
Service manual will tell you more on electrics if you want to check coil & stator resistance etc.
Apr 20, 2026 at 10:39 PM #22367
HawkonairParticipantIt’s likely not necessary because it only activates with full throttle and doesn’t pump continuously; it’s probably just for priming before the first start.
Alright, if it’s not strictly necessary, I’ll just leave the 250cc carburetor in.
Installed the 250cc carb using 125cc intake hoses to maintain vacuum delivery.
Okay, if you say the electronics are all identical, including the coils and everything, then I’ll leave it just as it is.
Apr 21, 2026 at 7:45 PM #22368
HawkonairParticipantThe bike runs only with the choke on; it accepts throttle, but stalls at idle without the choke.
Apr 21, 2026 at 8:10 PM #22369
♠️ M77KeymasterClean the carbs , check your jets , and you probably need to check engine compression to make sure its good.
Apr 22, 2026 at 5:21 PM #22374
HawkonairParticipantIt’s running, just needs an oil change and I’m looking forward to the drive.
May 15, 2026 at 10:00 PM #22576
Cobra2ParticipantGood job! Now let us see a picture of your bike…
