Viewing 2 reply threads
    • #20045
      Jreen
      Good evening,
      I am trying to fix my throttle cable for my GV250 Aquila, im lost, please someone give me some pointers? Any help is appreciated, thanks.
      Kindly, Jesse.
    • #20050
      This one , will fit , super cheap because it is slightly frayed as you look at the close pics but use these as a temporary measure:~
      https://www.ebay.co.uk/itm/256596740409
      If not,  it is possible i can acquire another EFi throttle cable locally here in UK and export it to you ,  but send me an email about it  (“Contact” at the bottom of the site)
      Generally i don’t mention other sources online because you will find maybe 5-10 Hyosung websites all using the same design, same background, they are clones with a lot of angry customers due to scammy behavior and members on this forum have also reported the same,  so be wise when shopping around too.
    • #20055
      Simon
      I would add you can get cables from Wemoto they are a proper shop & having purchased in the past they are perfect in fitting & size
