- This topic has 3 replies, 2 voices, and was last updated 5 years ago by ♠️ M77.
Mar 22, 2021 at 10:59 AM #5641
Hello everyone,
I am a new member with some bike issues, I have a 2008 GT 650 comet, naked one, The bike was running absolutely spot-on before I stored it over the winter, I taken the battery off and recharged it, I know I keep getting the dreaded F1 light and it won’t start ,
any help would be appreciated guys n girls as I have NO CLUE as to why or what’s happening
Mar 23, 2021 at 4:56 PM #5645
Have you checked the forum for a 2008-2010 efi manual ? There is a page that shows you how to trick the ECU to display diagnostic code on the dash.
Instead of a switch, people sometimes put a paper clip across the 2 pins under the pillion seat , but caution when you do this though!
Mar 23, 2021 at 5:24 PM #5646
I haven’t, but I will
mines is a carb model tho, is it the same as the efi???
Mar 25, 2021 at 7:53 PM #5653
I haven’t, but I will mines is a carb model tho, is it the same as the efi???
F1 light shouldn’t be there. The EFi dash is only for the EFi machines with an EFi ECU
So if you have a carby bike, then you have a CDI which has simpler electronics, it would require a Carby Dash. Tell us the part number on your CDI if you can and also if possible upload a picture of your carbs between the engine on this site.
