Viewing 2 reply threads
    • #21537
      enjuan
      Hello Everyone!
      I have had my 2013 Hyosung GT650R EFI for about 2 years now and had no issues with my coolant temps before. Although I have replaced my Stator + Regulator for about 6 times now. But my current Issue right now is the temperature. After riding through the motorway for about 10 mins the temps are completely fine without any trouble, But once I reach the City and stopping at intersections, The Temperature Gauge starts climbing from 4 bars up to almost it’s maximum temp. I’ve checked the fans and they turn on, I’ve done a coolant flush + new coolant into it. I have checked the reservoir and it’s topped up aswell. Still showing the same issues.
      Any help and advice would be excellent!
      Voltages:
      Idle : 13.2V
      2-3K RPM : 13.4V
      5K RPM : 13.5V
      Stator + Regulator from AmotoPart
    • #21538
      6 times ? I would definitely recommend real japan proper mosfet regulator kits like the ones we do on the shop,  as the stock/replicar regulators fail more than the stator does.   It is just an idea.
      Right now, the bike is still charging OK!
      Temps = Thermostat and FAN Switch Sensor , these 2 will go crazy from time to time, so i would check your thermostat.  Also the FAN switch  or Engine Temp Sensor should be checked to see if they are in spec
      Testing the sensor involves using a pocket meter to check for OHMS readings and use the 650R service manual on this forum ==> the bike manual will advise what figures your sensors must have.
      Don’t dip them in water as the contacts will go bad!  (But it is OK to put only the “gold tip” inside the warm water on your table == get a glass home thermometer  , put it inside the bowl ,  it will say water from your kettle is 55c   , so go to the manual and look for 55c ,   the sensor could be saying 700 OHMS at 55c  but the manual says it must be 400 OHMS , this means the sensor is reading out of spec ? Do this a few times to get a consistant figure before deciding to replace it or not)
      Thermostart , it should open at the temperature the manual says , otherwise you have trapped boiling coolant in the cylinders and ECU turns the fan on , but the thermostat did not OPEN to send hot fluid to radiator! – Just a possibility.
      Also try MOTUL FACTORY LINE coolant  = It is my favourite bike coolant ever. It just does the job well.   Castrol “might” be OK but i don’t trust their OILS!
      When you re-flush , be sure not to have trapped air in the cooling system too.
      Keep us posted & good luck.
    • #22142
      undocab
      Be sure
      •    after coolant flush there is no air in the system so coolant is circulating
      •    thermostat is working fine
      •    temperature working fine.
