Viewing 3 reply threads
    • #12086
      Mark lindsay
      What reading should a healthy stator have?
    • #12087
      0.7 ohms max ice cold (overnight cooled) – on all three yellow wires =  Beyond a single 1.0hm on any yellow wire means replace the whole unit.
      up to 140 ohms on pickup sensor ice cold.   = No hot readings for ohms because heat rises up resistance readings.
      Running =
      @5K revs should say 80-90v max AC on all three wires.   Identically.  Any yellow wire that isn’t in spec = replace stator   (eg. 40 , 80, 80 instead of all 80 , 80 , 80 )
    • #12102
      Mark lindsay
      Im getting 1.1 on current bike I bought a stator and the reading is 0.9 healthy stator?
    • #12104
      Do a voltage test next when the bike is running , and report what each single yellow wire says  from my first reply above ^
      Eg.  Running @5K revs
      1.  … V AC
      2. … V AC
      3. … V AC
      Overnight Ice Cold  Pulse sensor = ohms
      Pulse Sensor Hot  = ohms
