    • #10500
      Ray
      Hi all. I have a 2012 650S. When I try to start the bike the starter spins but will not turn the engine over. It wasnt sounding right the last few time is kicked over. I have a new battery and have had the start tested So I dont think its a electrical issue. Pretty sure its machanical. The pinon gear is turning but is not driving the starter mechanism. And input would be greatly appriciated
    • #10520
      Sounds like the sprag clutch behind the flywheel has gone.  (I hope not)
      But open the magneto casing, then remove the flywheel carefully, look at the sprag clutch ,  if its ok, it could be due to missing teeth on the “Flywheel Sprocket”
