Viewing 4 reply threads
    • #11293
      Stubz
      My 2016 gt650r just stopped starting . When o press the start button all it does is click . The fuel pump is running when ignition is switched on
    • #11294
      Jason
      If you hear a click then most likely it is the starter motor.  I noticed you are in Australia, so am I.  If you need spares let me know.
      • #11321
        Stubz
        If u have a spare starter motor that would be awesome i am in qld but i see ur in canberra
    • #11296
      Simon
      Starter solenoid or low battery most likely cause
    • #11329
      You can PM him , if that helps
    • #11330
      Jason
      I dont have a spare starter unfortunately.   Have you tried putting 12v directly on the starter to see if it works?
