Viewing 2 reply threads
    • #5737
      Ian
      hi anyone known where I can get a rec/reg for my st7 any replies appreciated.
    • #5739
      Simon
      It is something that’s worth upgrading I run a shindengen sh775 series regulator you need to do a bit of wiring, you can get pattern parts etc cheap the gt650 uses the same as st but not reliable it is the one part of the hyosungs that’s pretty grim.
    • #5742
      I have had clients email me to make a custom harness and supply an aftermarket reg with a good stator unit, I had to send all 3 together to do away with the stock Hyosung 650 charging system even the stator was near the oem service limit,  it was better to do it all & over with  , but i understand it isn’t cheap either.   I wouldn’t use cheapo units tbh (taiwanese made).    If the Korea’s outsourced daewoo part was bad, i can’t see taiwanese folk doing better.
