Viewing 2 reply threads
    • #13480
      tabea
      Hello
      Just went on a ride, after taking a break the speedsensor stopped working out of nowhere..should i just try to clean it? a used one cost like 100 euros..D:
      cable connection is fine
    • #13501
      If it says 0mph while riding =  It means you will need to remove speed sensor from wheel,  check it moves OK, it might have water inside ?  Grease it heavy and hopefully it works again.
      It is possible to open it to see if anything is damaged but i warn you,  it might not work again if you open it! – So be wise.
      If in doubt,  try to replace it and try again.
      if the sensor is new , then check the plug on the harness because the speedometer gets signal directly from the sensor at the connector in your harness.
    • #13505
      tabea
      i think it just gave up, i opened the sensor cleaned and regreased it but no changes, i just take the risk to order another one
