Viewing 2 reply threads
    • #5951
      Sam
      Hello everyone. The screen of the bike started flashing on and off randomly. Then it stop working completely. However, later on the screen started not to turn off when I switch the engine off and drained the battery more than once. I have replaced the battery as I thought it might solve the problem but unfortunately it was not the issue here. Please help. I went to many mechanics around and they asked me to change the whole speedometer screen. But if it’s not functioning then why it drains the battery?.
    • #5962
      Simon
      It could well be the unit has had it but try all the connections disconnect them give them a clean & try that first.
    • #5963
      Sam
      So it is possible for the unit to drain the battery if it’s damaged? As I mentioned before. When the bike is switched off. (Key completely removed) the screen most often remains on for short or long time randomly. I will the suggestion and update ASAP
