Viewing 2 reply threads
    • #14239
      Aquila Queen
      Hi there guys, my GV125c was recently stolen and had the instrument cluster pulled off in order to get to the ignition. I was wondering if the comet 125 clocks would make a good substitute? The only Aquila clocks I can find are well over £300 and is almost as much as I paid for the bike in the first place 😂
    • #14247
      I believe you may have to fork out that much but….
      Can we verify a few things first….
      – What year is the GV ?
      – Did the old clocks have a “Classic Fuel Guage” in the middle   or did it have a “DIGITAL LCD” fuel gauge
      Classic Dash  = Fuel gauge is yellow with a real needle sweeping up. and it uses a manual speedo drive with a cable going straight up to the dashboard from the left side of the front wheel
      LCD = Fuel Gauge is like a black & white TV with text , it lights up WHITE  , the speedo mph uses an “Electric Speed Sensor”
      If in doubt, grab a picture showing us what your old GV dash looked like if possible!
      Hyosung might have keeped the same body shape around 2006-2017 but they changed electrics internally, plus  GV generally isn’t backwards compatible with GT clocks, they made sure of that without the rider being an electric wizard to re-work it.
      • #14265
        Aquila Queen
        It’s a 2016 model with the digital fuel gage. Thought this could be the case with compatibility with the electrics  😅
    • #14269
      Your particular model requires that exact digital dash , as the older versions will not work with your digital speed sensor too.
      GT = Too much headache and their “fuel gauge” will say EMPTY when tank is full and  FULL when tank is empty! (GV uses reversed sensors!)
