- This topic has 7 replies, 3 voices, and was last updated 2 years, 7 months ago by
♠️ M77.
Apr 10, 2024 at 8:46 PM #12907
WillParticipantHi guys ,what spark plugs does my hyosung gv 125s on a 22 plate take ,as I want to do my own service on it as bought it private,many thanks 👍
Apr 10, 2024 at 9:17 PM #12908
♠️ M77KeymasterGood for you! – I guess its one way to learn about the bike but don’t rush anything. The factory plug is CR8E which you find at any local halfords
Hyosungs do NOT like “Iridium IX” (The blue boxes) – Overhyped junk plugs tbh and only good for 5k miles.
NGK’s best plug is the Laser Platinums , like what you see in this forum store. 👍
Ignore CR7 , CR9 = the bike will get in a bad mood later on. Just CR8E is more than enough for the entire year. So ignore anyone saying it’s better to use incorrect plugs. I always throw away incorrect plugs whenever i fix a customer bike. And i either use CR8E or Laser (if they want to upgrade it with ngk’s ht leads with it) Since the OEM black leads commonly fail (Hyosung doesn’t make the HT leads, so it’s just a common outsourced unbranded part for various bikes)
Apr 10, 2024 at 10:14 PM #12911
WillParticipantThank you Marcel,be assured if I need any more help or not sure on something you’ll be my first person I contact 👍
Apr 21, 2024 at 2:13 AM #13017
NorthmanParticipantMarcel. Would I lose the warranty by changing the cables for the ngk ht ones?
Apr 21, 2024 at 4:19 PM #13035
NorthmanParticipantWhat’s wrong with the Iridium IX? it’s because of OEM wiring?
One of my friends has the iridium IX on his yamaha and hasn’t changed them in 40,000km, they work perfectly
Apr 21, 2024 at 6:34 PM #13042
♠️ M77KeymasterMarcel. Would I lose the warranty by changing the cables for the ngk ht ones?
Not really if if you allow a garage to install it for you, then warranty should be OK but………. because if you lose warranty then bike will still be grateful you got rid of the black caps, they cause too many issues right now. That’s why you never see us selling brand new OEM black caps. 99% of Hyosung owners worldwide change it even 650 owners. Hyosung doesn’t make the black caps, it is an outsourced part. (too cheap made) , NGK rarely fails.
IX Plugs = Hyosung’s just don’t like them. Some other brand bikes are OK with it. So hence we generally recommend stock CR8E or LASER Platinum. Laser Platium is NGK’s best street level plug. And race bikes use it too.
Apr 22, 2024 at 7:45 AM #13050
NorthmanParticipantOh I see.
Do you mean these:
NGK Upgrade HT Plomo Tapas de Bujía x2 Hyosung GV125-S EFi (hyoriders.club)
Bujías NGK LASER Iridium x2 – Hyosung GV125S (EFi inyectado) | Reino Unido (hyoriders.club)
When you say “platinum”. Do you mean spark plugs that are made of iridium but “platinum edition” or spark plugs made of platinum? It’s easy to get confused because the boxes are so similar:
Apr 22, 2024 at 4:57 PM #13058
♠️ M77KeymasterHey, read here from the official NGK website (they changed name to Niterra now)
https://www.ngkntk.com/products/spark-plugs/
Click where it says “Platinum”
If you don’t see it , it says this“Platinum Spark Plugs
These spark plugs are equipped with a platinum plate on the middle electrode. This ensures a more constant output of the spark plug over the entire service life, even under difficult conditions. Based on its narrow middle electrode, it emits very little spark voltage. Moreover it discharges the ignition coil, and ensures optimal combustion.”They sell “LASER” as Platinum or Iridium Platinum = As long as the box is “rainbow color” in their text, that is the best plug for street use. It is more long laster than cheaper “IX Iridium” which has a blue box.
And yes to the 2 links you posted from the shop
