    • #12728
      Hugoboss8901
      Hello, I currently ride a 2020 hyosung gv125s aquila bobber.
      I love this bike but I have one problem
      The rightside dictator doesn’t always work. The left one no problem but the right is very temperamental. So sometimes it works and sometimes it doesn’t. If I flick the switch a few times then it works but I don’t always have time to do this as I ride in the city I need my focus on the road and not trying to get my indicators to work.
      If I flick the switch to the right I can bypass this by putting on the hazards which the right side then works.
      Anyone have idea on this ? I ve very limited knowledge when it comes to bike electrics.
      Many thanks
    • #12736
      If you have a spare 2hours,  head to halfords => Get “Contact Cleaner” and ACF50
      1.  Remove the switch gear apart slowly.
      2. Spray contact cleaner on the contacts inside that control the indicators.
      3. Wait to dry.
      4. Apply ACF50 a little dolop in the same place
      5. Close the switch gear and try again ?
      If not , open the head light unit and see if you find wires for the indicators there , as hyosung hides front switch wires and indicator wires inside the headlight casing  (sometimes!)
      Also , open then right indicator cover lense and slowly push down, twist the bulb to pop it out,  then clean and ACF50 the contacts the bulb sits on.
      Hopefully these small tasks , might get us somewhere before having  to tear down the bike fully.
      You got this!
