    • #22366
      Hyobusa
      Hi All,
      I’m currently tackling the g125r 2012 project, and the issue I see that I will have to dig into in my next stage after I fix carbs, is the rev counter.
      The problem I see is that it activates on the key switch, goes from zero to the top and back as it should; however, when I manage to start the bike, it doesn’t read engine RPM.
      Would anyone have any suggestions to fix this issue?
    • #22370
      Check the yellow wire from behind the dash itself, it’s yellow with a black line on it, follow it all way down to your harness , then same wire appears at the front coil , likely harness issue.
      • #22371
        Hyobusa
        Thanks for the suggestion, I’ll dig into it.
