    • #15006
      Magnus
      Hi all having some trouble replacing my left clip on bar after it snapped. (Got in a bit of a scrape, I am uninjured)
      Got the old bar off with the grip and removed the clutch lever, and indicator box and things but from here I’m a bit lost.
      I’m assuming I’ve got to remove the top yoke, how do I go about this? From what I can see the clip ons are attached underneath to the top yoke and I can’t get the bolt that binds them together off at all. I also think the top yoke is attached to the frame by 2 bolts underneath as well which are very hard to reach.
      Any guidance is appreciated as I’m close to giving in and calling a shop.
    • #15008
      1st step, 30mm socket and a big torque wench , then undo the big center nut on top yoke.
      Then use allen keys to remove the 8mm bolts on either side of the top yoke plate.
      Get a rubber mallet and tap the top yoke upwards until it comes out.
      It will come out with both clip ons still attached to it
      So make sure to loosing the bolts holding the clip-ons to the fork legs too.
