Viewing 3 reply threads
    • #13180
      Peter
      Hi
      While reassembling the carbs on the girlfriend’s GV250 I managed to snap the a corn nut threads. The replacement part number is 13329HG5100. It’s the hex cap for the sliding needle in the carb bowl.
      Has anyone an idea please how do get a replacement in the US? Isn’t there a way to get replacement parts from Mikuni by identifying which carb we use?
      Any input is appreciated.
    • #13189
      Send us an email as we have loads of them on this site’s shop pages.
      Mikuni doesn’t make them anymore but we managed to get a lot of old stock, i would say that brass nut and the “mixture screws” are like the most delicated parts of carb!
      If urgency is a thing,  contact  SunCoastCycleSports in US , as we do buy their stock every now and them for the bikes we fix on our UK soil.  They may have an old carb laying around or a salvage bike to strip parts from.
    • #13538
      Peter
      Hi Marcel
      Thank you for your input. I reached out to Suncoast cycle sports but they didn’t have this part.
      Due to time constraints I ended up fabricating something myself instead of ordering from the shop but thanks for the reference there too.
      I used a stainless M5x0.8 bolt with hex head, cut the thread length to ~5mm length and drilled a 3mm deep 2.5mm hole. I had to add an additional washer to ensure the jet needle didn’t bottom out against the bolt blind hole.
      I would have used a hollow stainless M5 bolt and just spot welded the hex bolt shut if the delivery would have been faster.
      The motorcycle seems to be running fine but a longer ride will confirm.
      Thanks again for the help.
    • #13544
      Not a problem. Glad you sorted it. I gotta say i respect your creativeness!
