    • #22512
      braaam
      Good evening everybody,
      I have a problem with my Hyosung TE450 quad that I’ve been trying to diagnose for a while.
      Problem: As soon as I turn the ignition ON, the quad starts producing spark at a constant fixed rhythm. The spark timing/rhythm does not change at all, even while cranking or trying to start the engine.
      Things already checked:
      CDI tested by Carmo Electronics and confirmed working
      Pickup coil checked
      Spark plugs checked
      Ignition coil/bobine replaced for testing, but problem stayed the same
      The strange part is that the spark remains at the exact same constant interval no matter what the engine is doing.
      Maybe someone has seen something similar before. Or have any ideas for further action.
    • #22524
      Replace the coil entirely and get new plug caps , then re-test , you want to rule out that completely.
      Also open the stator casing and check the stator pickup sensor has not gone haywire ?  CDi sends sparks to engine coils based on this item first.
      Then double check the harness.
      We hope you don’t have to replace the CDI as the last resort.
